IP domains are required for monitoring environments with overlapping IP addresses. Create custom IP domains in CA Performance Center so that Administrators can assign items in CA Network Flow Analysis to the domains.
Note: We highly recommend that you set up domains in CA Performance Center and assign them to your Harvesters in CA Network Flow Analysis before you add routers. When you enable routers, they inherit the domain of their parent Harvester. The domain assignment for routers is permanent. You can change the domain assignment for Harvesters, interfaces, and CVIs at any time, however.
The Default Domain is created automatically. The Default Domain includes any items that are not assigned to a custom domain.
The page displays the current list of IP domains.
The IP Domains Administration dialog opens.
Identifies the domain.
(Optional) Describes this domain namespace, such as naming the enterprise that owns it.
Is the IP address of the primary name server for this domain.
Is the port number that the primary name server uses.
Is the IP address of the secondary name server for this domain. Can be the same as the primary address.
Is the port number that the secondary name server uses.
The new IP domain appears in the list.
