CA Network Flow Analysis must be registered with CA Performance Center so that administrators can set up SNMP profiles, domains, user accounts, user permissions, roles, and groups. SNMP profiles and domain setup are an essential part of data flow configuration.
Once you have registered CA Network Flow Analysis and have completed the needed administration tasks, operators can see meaningful reports in CA Network Flow Analysis and in CA Performance Center.
To configure CA Network Flow Analysis properly, you must perform the following tasks:
These tasks are described in the following topics.
For a complete workflow for this process, see the CA Network Flow Analysis bookshelf for the document "Register and Configure Network Flow Analysis in CA Performance Center."
