Previous Topic: Set Up Custom Reports
Next Topic: Review Settings for Custom Reports
Create a Custom Report
Use the Custom Report wizard to create a Custom Report step by step. The wizard guides you to select many options, such as the specific items on which to report, the presentation views, the reporting period, and, optionally, a schedule for running the report automatically.
  1. Select Custom Reporting from the NFA console menu.
  2. Click Create New Report.
    The Custom Report wizard opens and shows the options ‘Create a new custom report" and ‘Copy an existing report.’
  3. Click ‘Create a new custom report,’ then click Next.
    Note: Alternatively, you can select ‘Copy an existing report option’ and modify an existing report.
    The Select Interfaces page of the Custom Report wizard opens.
  4. Click one of the following options to select interfaces or interface groups for the report:
    The selected interfaces are added to the interface list.
    See Also: Select Interfaces and Interface Groups
  5. Accept the default value or set the Inclusion value for each interface or interface group: ‘Include’ sets the program to use report data from the interface or group. ‘Exclude’ sets the program to bypass data from the interface or group.
  6. Click next when you have specified all the interfaces to use for report data.
    The Specify Filters & Rollup page opens.
  7. (Optional) Specify the settings on the Specify Filters & Rollup page: Specify filters for gathering or excluding report data, then set the Inclusion value for each filter to Include or Exclude:
    See Also: Specify Custom Report Filters
  8. Accept the default value or set the Inclusion value for each filter you specified:
  9. Select at least one type of summary data to make available for display in the report. Your selections make various report sections available in a later wizard page, but do not require you to include them. Select one or more check boxes in the Summary Types section:
  10. (Optional) Specify a mask for rolling up data by subnet, if you specified a host or conversation filter: Click the ‘Rollup data using this mask’ check box, then select a mask from the list.
  11. Click Next when you have finished specifying options.
    The Configure Layout page opens.
  12. (Optional) Add one or more report sections to the report page layout:
    The new section is added at the end of the report.
  13. (Optional) Delete one or more report sections from the report page layout by clicking the X icon next to the section name.
  14. (Optional) Re-order the report sections in any of the following ways:
  15. Click Next when the report sections are listed correctly in the Added Reports list.
    The Specify Schedule page opens.
  16. Select the type of reporting period from the Period list in the Specify Schedule page:
  17. Enter the number of time units in the Resolution box. Select a value from the list for Start and End.
    A Start-and-End report runs on demand and cannot be set up to run on a schedule.
  18. Accept the default setting or enter the number of time units in the Resolution box. Select a unit of time from the list (minutes, hours, days, weeks, months, or years).
  19. (Optional) Select a time filter from the list, if your Administrator has created a time filter that is appropriate for your report.
  20. (Optional) Select the Schedule check box and specify the following options:
  21. (Optional) Enter the email addresses of all the report recipients in the format name@domain. Separate multiple addresses with a comma or semi-colon.
    The options in the Recurrence section are available only if you select ‘duration’ as the reporting period type.
    See Also: Define Custom Report Periods and Schedules
  22. Click Next when the Specify Schedule page settings are complete.
    The Enter Name page opens.
  23. Identify the report and its location, then click Next:
    The Summary & Submit page opens.
  24. Review the information in the Report Definition Summary.
