Previous Topic: Edit Watchdog Service Settings
Next Topic: Create Traps
View System Status
View the System Status page at any time to check the overall status of CA Network Flow Analysis components.
  1. Display the System Status page:
    The System Status page opens and shows a quick overview of the status of CA Network Flow Analysis components. Status symbols identify any components that have generated warnings. The number of warnings appears in parentheses after the component label.
  2. Click any component that has a warning symbol to see details.
    A table of warnings appears.
    A table of warnings appears when you click the warning symbol for a component.
  3. Review any warnings that you find for each component.
