Previous Topic: View System Status
Next Topic: How to Set Up Traps to Work with External Fault Management Tools
Create Traps
Create traps to notify network management when certain events occur. Administrators can create traps and must deploy any traps that users create.
CA Network Flow Analysis traps can be integrated with external fault management packages.
  1. Display the Add a Trap Configuration page:
    1. Select Administration from the NFA console menu.
    2. Select Alerts from the Administration page menu.
      The Trap Configuration page opens and displays a list of the current traps.
    3. Click Add.
      The Add a Trap Definition page opens.
  2. Define the trap description and the interfaces that the trap monitors:
  3. (Optional) Create a Utilization-based trap by providing the following information:
  4. (Optional) Create a Rate-based trap by providing the following information:
    For example, suppose that you create a Rate-based trap and establish thresholds for both the inbound and outbound traffic. The trap is triggered when the threshold is met during the defined period.
  5. (Optional) Create a Volume-based trap by providing the following information:
  6. (Optional) Create a Flow-based trap by providing the following information:
  7. Click Submit when the selections are complete.
    The trap is deployed.
    Note: Traps are sent to the destination that is defined in the application settings.
To delete a trap definition, click the trap description in the Trap Configuration page trap list. Click the Delete button that appears in Edit mode. Verify the deletion when prompted.
To edit a trap definition, click the trap description in the Trap Configuration page trap list. Make updates in the Trap Configuration page in Edit mode. Click Submit. The trap is updated.
