You can view the last 200 lines of logged activity in a log file for a Multi-Port Monitor process. In addition to logs for the Multi-Port Monitor processes, you can view the recent entries in the following logs:
Contains entries for communications from CA Application Delivery Analysis to Multi-Port Monitor, including heartbeats and feed status updates.
Also contains requests for the network health information that appears on the Defect Details page in the APM console.
Contains entries that record packet capture investigation requests from CA Application Delivery Analysis.
Contains entries for every condition that triggered an SNMP trap.
The System Logs page opens.
The System Logs page refreshes to show the size of the log you selected. For example:
The file nqInspectorAgentd_20110228.log is 300160 bytes in size.
The System Logs page refreshes to show up to the last 200 lines of the log you selected.
