Previous Topic: The Analysis PageNext Topic: Analysis Menu
What is an Analysis?
An analysis is a description of a troubleshooting path into packet-level session data that is stored on the Multi-Port Monitor appliance. The description proceeds as a series of hierarchically organized views of the data.
Multi-Port Monitor offers two types of analysis.
Predefined Analysis
Provides access to IPv4-based TCP session-level information that is used when drilling in from a CA Application Delivery Analysis report or CA APM Defect Details page.
For example, you examine the CA Application Delivery Analysis Components report and narrow the data for the 192.94.5.6 network. When you click the Session Analysis button, an analysis for the selected report appears on the Multi-Port Monitor Analysis page. The selected network and time frame filter the session-level data in the analysis.
Custom Analysis
Provides options for filtering and viewing session-level metrics that speed up the troubleshooting process. The Multi-Port Monitor user can create, save, and reuse custom analyses.
For example, the drilldown, or Session Analysis, path from CA Application Delivery Analysis places you in a preselected context that is not applicable to your situation. You create an analysis or open a saved analysis to save some steps in selecting the desired views and their hierarchical arrangement. The associated charts and tables provide a sufficiently narrowed perspective on the data you want to analyze.
All analyses are displayed in the Analysis pane, to the left of the Display area on the Analysis page.
Filters are added to analyses at the view level and are applied to all subordinate views within the same analysis.
New analyses do not contain default data views. Add a view to data before applying a new analysis.
