Previous Topic: Overview of CA Application Delivery Analysis DataNext Topic: Recommended Configuration
Support for CA Transaction Impact Manager
Multi-Port Monitor captures HTTP packets for CA Transaction Impact Manager (TIM).
When CA TIM is installed on the Multi-Port Monitor appliance, the resulting converged appliance provides visibility into the application and network-level data of application usage per user. As a standalone appliance, CA TIM monitors HTTP transactions in real time and generates defects when it detects anomalies. Multi-Port Monitor provides session-level data at 1-minute intervals. With the converged appliance, this finer granularity of data can be used to investigate the defects that CA TIM detects. Use the CA APM console to drill down from defects to related data in the Multi-Port Monitor web interface.
The web interface lets you perform administrative and maintenance tasks for CA TIM.
The following diagram shows the components in a network in which Multi-Port Monitor, CA APM, and CA Application Delivery Analysis are installed.
Architecture for TIM and MTP
As shown in the diagram, Multi-Port Monitor can support CA TIM and CA Application Delivery Analysis simultaneously. In this scenario, packets for CA TIM and CA Application Delivery Analysis are processed in parallel. Separate RAM disks help buffer packets for both applications.
More information:
What are the Default Hardware Filters?
Install the CA TIM Software
