Previous Topic: Customize
Parameter File
To create a CA MAT list data set through CA MAT, you can edit the parameters in the parameter file listed in the following table:
Parameter entry
What you should enter
RP00075
Primary space (Default is 00075.)
RS00030
Secondary space (Default is 00030.)
RUSYSDA
UNIT (Default is SYSDA.)
RV
VOLUME (Default is blank.)
RO
STORAGECLASS (Default is blank.)
RM
MANAGEMENTCLASS (Default is blank.)
RD
DATACLASS (Default is blank.)
