Use the following steps to customize CA MAT:
---------- CA Mainframe Application Tuner -- Primary Option Menu ----------- OPTION ===> 0 Parameters - Enter user-specific parameters Userid: TUNUSER Server ID: MATUNER 1 Monitor - Create and analyze Monitor Sets Status: INACTIVE Version 9.0.00 2 Active - Select an active job to monitor 3 Registration - Register source listings 4 Grouping - Define groups of monitors 5 External - Analyze other user's monitor files S Status - Display and manage invoked monitors G Global - Global monitoring and listing registration A Administration - CA MAT system administration M Messages - List CA MAT messages T Tutorial - CA MAT tutorial ***************************************************************** * CA Mainframe Application Tuner Version 9.0.00 * * Copyright (c) 2012 CA. All rights reserved. * ***************************************************************** Copyright 2009 Enter an option or press END to exit AQM Solutions, a TRILOGexpert Company
TUN@GLOB--------------------- Global Monitoring Menu ------------------------- OPTION ===> 0 Parameters - Enter global monitor parameters Userid: TUNUSER Server ID: MATUNER 1 Monitor - Create and analyze Monitor Sets Status: INACTIVE Version 9.0.00 2 Active - Select an active job to monitor 3 Registration - Shared listing registration 4 Grouping - Define groups of monitors S Status - Display and manage invoked monitors
Enter an option or press END to return to the CA MAT Primary Option Menu
Batch Options for CodeView Threshold ===> 1.00 CodeView mode All-User-Top5 ===> Y Csect ===> Y Histogram Csect 1 ===> Module ===> N Histogram Csect 2 ===> Pseudo ===> N Histogram Csect 3 ===> 4GL ===> Y Histogram Csect 4 ===> Batch Options for DataView Linklist ===> N DB2 Code Detail ===> Y Batch Options for TranView Code Detail ===> N Delay Detail ===> N Data Detail ===> N Transaction 1 ===> * Transaction 2 ===> Transaction 3 ===> Transaction 4 ===> Batch CSV Output File Parameters Tracks Primary ===> 15 Secondary ===> 15 Volume Serial ===> or Storage Class ===> Unit ===> SYSALLDA Data Class ===> Management Class ===> Batch JES Parameters Lines per page ===> 60 Sysout class ===> * Column width ===> 80 Sysout form ===> Destination ===> JES Writer Name ===> Report Scope Report Detail ===> N Field Detail ===> N Batch Job Cards ==> //MATBATCH JOB (123456789),'CA MAT BATCH REPORT', ==> // CLASS=A,MSGCLASS=A,MSGLEVEL=(1,1),REGION=0M, ==> // NOTIFY=&SYSUID ==> //MATJCL JCLLIB ORDER=CAMAT.JCLLIB
This information is necessary for the CA MAT job to create the Report data set.
