Previous Topic: Using the PanelNext Topic: Using the Panel
Central Component Alert Delete Options
Option 5 of the Maintenance Menu allows you to define the options to be used for automatically deleting alerts within the Central Component.
APCBP902 --- PMA - Alert Delete Options --------------------------------------- COMMAND ===> Define the lifetime of alerts for job steps. Immediate delete of alerts in TSO: N Y,N (processed with ENTER key) State Days until deleted Alert state description ------------------------------------------------------------------------------- PEND 190 Alert waiting for a measurement OPEN 090 Alert waiting to be processed by user REV 360 Alert in process by user CUSE 360 Alert closed by user CMUL 360 Alert closed because multiple implicit closes COVT 360 Alert closed by take over (new statistical base) CTHR 007 Alert closed because out of scope of work CIMP 007 Alert closed implicit by statistics Cancel: CAN Save : END OR PF3
The Alert Delete Options panel should be used to define the alert lifetime and/or the method to be used when automatically deleting alerts within the Central Component.
