Previous Topic: Central Component Measurement or Measurement AccessNext Topic: Central Component Alert Delete Options
Using the Panel
  1. To sort the information listed in the columns, use the SORT primary command for the column in which the lines should be sorted.
  2. To delete unwanted measurements, enter line command D in the LC column to the left of the unwanted measurement.
