Previous Topic: Steps 2—6Next Topic: Data Maintenance
Return Codes
Check the return code after the job completes.
Possible return codes are listed following.
Return Code
Description
RC 0
Normal completion; all values were OK.
RC 4
Process finished; values exceeding format directions have been adjusted.
RC 8
Process finished with errors; error toleration limit was not exceeded.
RC 12
Process was stopped by errors exceeding the toleration limit.
Job APCIJS34—Importing IMS Data from SysView
You also can use job APCIJS34 to import IMS transaction execution information from SysView IMS History Log.
The JCL for job APCIJS34 is in the PMA.CNTL library in member APCIJS34.
Job APCIJS34 performs the following steps while importing the data.
Job Step
Description
Step 1
Extract SMF 255(34) from APCINF
Step 2
Scope handling - verify data against defined In-/Exclusions
Step 3
Sort 1
Step 4
IMS transaction information import phase 1
Step 5
Sort 2
Step 6
IMS transaction information import phase 2
Step 1
Convert user-provided input to the internal format
DD Statement Information
Provide the SysView IMS transaction history log records in the form of SMF type 255 subtype 34 as a sequential file under DD statement APCINF.
Each file record must contain the IMS transaction information in the required format. (For a complete description of the format requirements, see Format Requirements for the IMS Transaction Information Interface.)
Other DD statement information is shown next.
DD statement
Organization
Format
Record length
Description
APCINF
PS
VB
VB 32760
input file with the SysView for IMS transaction log records
APCOUTF
PS
VB
3120
temporary output file, input for next step
APCREP
PS
FB
80
information messages
APCEREP
PS
FB
80
warning and error messages
JCL Example
Extract the transaction execution information and convert it to internal format as shown next.
In the first step, the provided IMS transaction information is checked for data validation and converted to the required format for further processing.
Be sure to make the following changes:
  1. Provide the name of the sequential file that contains the SysView for IMS transaction log records under DD statement APCINF.
    //APCIAS34 EXEC PGM=APCIAS34
    //STEPLIB  DD DISP=SHR,DSN=CAMAT.PMA.CEETLOAD
    //APCINF   DD DSN=SMF.INPUT.DATASET
    //            DISP=SHR
    //APCOUTF  DD DSN=&&APCIMS1,
    //            DISP=(,PASS),
    //            UNIT=SYSDA,
    //            DCB=(RECFM=VB,LRECL=3120,BLKSIZE=27998),
    //            SPACE=(CYL,(10,20))
    //SYSABEND DD SYSOUT=*
    //*YSUDUMP DD SYSOUT=*
    //APCREP   DD SYSOUT=*,DCB=(RECFM=FB,LRECL=80)
    //APCEREP  DD SYSOUT=*,DCB=(RECFM=FB,LRECL=80)
  2. Run steps 2 through 6 of job APCIJS34, as shown following.
In these steps, the input data is tested against the defined Scope (In-/Exclusions), the summary regions (if defined) are built up, and the data is stored in the database.
//* ACTION:      CHECK INPUT FOR SYSTEM/TRX IN/EXLUSIONS             *
//APCIASDI EXEC PGM=APCIASDI,REGION=4M
//APCINF   DD DSN=&&APCIMS1,
//            DISP=(OLD,DELETE)
//APCOUTF  DD DSN=&&APCIMS2,
//            DISP=(,PASS),
//            UNIT=SYSDA,
//SYSUDUMP DD SYSOUT=*
//APCBEXC1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSEXC
//* ACTION:      SORT EXTRACTED IMS INFORMATION                      *
//SORT01  EXEC PGM=SORT
//SORTIN   DD DSN=&&APCIMS2,
//SORTOUT  DD DSN=&&APCIMS3,
//            DISP=(,PASS),
//            UNIT=SYSDA,
//SYSOUT   DD SYSOUT=*
//SORTDIAG DD SYSOUT=*
//SYSIN    DD *
  SORT FIELDS=(5,8,CH,A,23,4,BI,A,13,9,CH,A,27,5,BI,A)
//* ACTION:      PROCESS SORTED IMS RECORDS                          *
//APCCASSA EXEC PGM=APCCASSA,PARM='IMS'
//APCPARAM DD DISP=SHR,DSN=CAMAT.PMA.PARMS
//APC110I  DD DSN=&&APCIMS3,
//APC110O  DD DSN=&&APCIMS4,
//            DISP=(,PASS),
//            UNIT=SYSDA,
//            DCB=(RECFM=VB,LRECL=255,BLKSIZE=27998),
//APCCCST1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSCST
//APCCDIC1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSDIC
//* ACTION:      SORT INTERIM IMS RECORDS                            *
//SORT02  EXEC PGM=SORT
//SORTIN   DD DSN=&&APCIMS4,
//SORTOUT  DD DSN=&&APCIMS5,
//            DISP=(,PASS),
//            UNIT=SYSDA,
//SYSIN    DD *
  SORT FIELDS=(5,8,CH,A,21,4,BI,A,13,8,CH,A,25,2,BI,A)
//* ACTION:      PROCESS SORTED SMF RECORDS                          *
//APCCASSB EXEC PGM=APCCASSB,PARM='IMS'
//APC110I  DD DSN=&&APCIMS5,
Return Codes
Return Codes
Possible return codes are as follows:
Return Code
Description
RC 0
RC 4
RC 8
RC 12
