Run steps 2 through 6 of job APCIJM44, as shown following.
In these steps, the input data is tested against the defined Scope (In-/Exclusions), the summary regions (if defined) are built up, and the data is stored in the database.
//******************************************************************** //* * //* ACTION: CHECK INPUT FOR SYSTEM/TRX IN/EXLUSIONS * //* * //******************************************************************** //APCIASDI EXEC PGM=APCIASDI,REGION=4M //STEPLIB DD DISP=SHR,DSN=CAMAT.PMA.CEETLOAD // DISP=(OLD,DELETE) //APCOUTF DD DSN=&&APCIMS2, // DISP=(,PASS), // UNIT=SYSDA, // DCB=(RECFM=VB,LRECL=3120,BLKSIZE=27998), // SPACE=(CYL,(10,20)) //SYSUDUMP DD SYSOUT=* //APCBEXC1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSEXC //APCREP DD SYSOUT=*,DCB=(RECFM=FB,LRECL=80) //APCEREP DD SYSOUT=*,DCB=(RECFM=FB,LRECL=80) //* //******************************************************************** //* * //* ACTION: SORT EXTRACTED IMS INFORMATION * //* * //******************************************************************** //SORT01 EXEC PGM=SORT //SORTIN DD DSN=&&APCIMS2, // DISP=(OLD,DELETE) //SORTOUT DD DSN=&&APCIMS3, // DISP=(,PASS), // UNIT=SYSDA, // DCB=(RECFM=VB,LRECL=3120,BLKSIZE=27998), // SPACE=(CYL,(10,20)) //SYSOUT DD SYSOUT=* //SORTDIAG DD SYSOUT=* //SYSIN DD * SORT FIELDS=(5,8,CH,A,23,4,BI,A,13,9,CH,A,27,5,BI,A) /* //*
//******************************************************************** //* * //* ACTION: PROCESS SORTED IMS RECORDS * //* * //******************************************************************** //APCCASSA EXEC PGM=APCCASSA,PARM='IMS' //STEPLIB DD DISP=SHR,DSN=CAMAT.PMA.CEETLOAD //APCPARAM DD DISP=SHR,DSN=CAMAT.PMA.PARMS //APC110I DD DSN=&&APCIMS3, // DISP=(OLD,DELETE) //APC110O DD DSN=&&APCIMS4, // DISP=(,PASS), // UNIT=SYSDA, // DCB=(RECFM=VB,LRECL=255,BLKSIZE=27998), // SPACE=(CYL,(10,20)) //APCCCST1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSCST //APCCDIC1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSDIC //SYSUDUMP DD SYSOUT=* //APCREP DD SYSOUT=* //APCEREP DD SYSOUT=* //* //******************************************************************** //* * //* ACTION: SORT INTERIM IMS RECORDS * //* * //******************************************************************** //SORT02 EXEC PGM=SORT //SORTIN DD DSN=&&APCIMS4, // DISP=(OLD,DELETE) //SORTOUT DD DSN=&&APCIMS5, // DISP=(,PASS), // UNIT=SYSDA, // DCB=(RECFM=VB,LRECL=255,BLKSIZE=27998), // SPACE=(CYL,(10,20)) //SYSOUT DD SYSOUT=* //SORTDIAG DD SYSOUT=* //SYSIN DD * SORT FIELDS=(5,8,CH,A,21,4,BI,A,13,8,CH,A,25,2,BI,A) /* //* //******************************************************************** //* * //* ACTION: PROCESS SORTED RECORDS * //* * //******************************************************************** //APCCASSB EXEC PGM=APCCASSB,PARM='IMS' //STEPLIB DD DISP=SHR,DSN=CAMAT.PMA.CEETLOAD //APCPARAM DD DISP=SHR,DSN=CAMAT.PMA.PARMS //APC110I DD DSN=&&APCIMS5, // DISP=(OLD,DELETE) //APCCCST1 DD DISP=SHR,DSN=CAMAT.PMA.KSDSCST //SYSUDUMP DD SYSOUT=* //APCREP DD SYSOUT=* //
