Previous Topic: Column DescriptionsNext Topic: Panel Elements
IMS load Module Libraries
When you choose option I3 on the Parameters Menu, the List Load Libraries panel is displayed. Use this panel to enter the load module libraries that Performance Management Assistant should examine.
APCBPP05 --- PMA IMS Feature - List Load Libraries ----------- Row 1 to 2 of 2 COMMAND ===> SCROLL ===> HALF Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change LC Dataset name ------------------------------------------------------------------------------- PROD.IMS.LOAD2 ******************************* Bottom of data ********************************
If you have not previously entered any load libraries, the insert panel is displayed and you are requested to enter the name of the load module library to be examined.
The load libraries defined here are examined in batch to determine whether programs have been modified.
If a new load library is defined, Performance Management Assistant detects this library automatically and prevents all pre-existing modules in the new load library from being measured as new modules.
