Previous Topic: Maintaining the Database - APCIJRDRNext Topic: Global Online Parameters
Defining Parameters
To view or edit the IMS Feature parameters, select the PARAMETERS option on the Main Menu. The Parameters Menu is displayed.
APCXPP00 --- PMA --- Parameters Menu -------------------------------------- Enter an Option ===> TSO User U1 Print Job JCL Global Parameters G1 Measurement DS processing Global Online Parms G2 CICS and IMS Central Component X1 General Central Component Parameters X2 Scope of Work X3 Standard Programs X4 Standard Procedures X5 Load Module Libraries X6 Job Libraries X7 Procedure Libraries AS MODC Alert suppression Thresholds TA Absolute Alert Thresholds TX Performance Index Alert Thresholds TM Minimum Consumption Thresholds TH Open Alert Thresholds PMA SERVER S1 General PMA SERVER Parameters CICS Feature C1 General CICS Feature Parameters C2 System Control C3 CICS Load Module Libraries C4 CICS SMF Scope Definitions C5 CICS SMF Aggregation Control IMS Feature I1 General IMS Feature Parameters I2 System Control I3 IMS Load Module Libraries I4 IMS INFO Scope Definitions I5 IMS INFO Aggregation Control
If the entire menu does not fit on your screen, press F8 to view the remaining options.
All users need update access authority to the parameter data set.
To use the Parameters Menu, type the selection number in the Enter an Option field. The following list shows the parameter options:
G2
Define global online thresholds for CICS and IMS
I1
Define general parameters to be used by the IMS Feature (for example, password, TOP Limit, thresholds)
I2
Define the system control parameters for the IMS Feature
I3
Define the IMS load module libraries
I4
Define regions and/or transactions that can be handled by the IMS INFO Feature
I5
Define summary regions for the IMS INFO Feature
