Previous Topic: General ParametersNext Topic: Column Descriptions
IMS Feature System Control
The System Control panel is displayed when option I2 on the PARAMETERS selection window is chosen.
APCDPP02 --- PMA IMS Feature - System Control ---------------- Row 1 to 3 of 3 COMMAND ===> SCROLL ===> HALF Commands : CAN - CANcel INS - INSert Line Commands: I - Insert D - Delete C - Change System name LC PMA PMA Jobname Start time HH internal ID System name from to ------------------------------------------------------------------------------- 001 IMS1 IMSSYS1 00 24 002 IMS2 IMSSYS2 00 24 003 IMS3 IMSSYS3 00 24 ******************************* Bottom of data ********************************
The System Control panel shows you the default processing results of job APCYJLNA. APCYJLNA adds a new entry in this list for every new job name of an IMS region that is processed. By default, each new entry is added with a new distinct internal ID and the job name is used as the system name.
When creating system names, consider using appropriate definitions for the later easy use of wildcards for selecting systems that should be included for reporting or other tasks.
The following functions can be performed by using the System Control panel:
With the IMS Feature, information about measurements can be aggregated to information for a whole online system. To understand this concept, assume the following parameters:
ID
System Name
Jobname
Start time from/to
8
IMS01
IMSMPP1
00  24
8
IMS01
IMSMPP2
00  24
8
IMS01
IMSMPP3
00  24
Using the illustration above as an example, all measurements of IMS regions IMSMPP1, IMSMPP2, and IMSMPP3 are interpreted and calculated by Performance Management Assistant to one logical system IMS01. In the online dialog of PMA, the data of the measurements is seen as one although a transaction is called in all three regions. Thus, Performance Management Assistant aggregates the data of three measurements. For controlling transaction performance, look at the online panels for the specific transaction in system MRO as one line of information.
ID
System Name
Jobname
Start time from/to
28
IMSMORN
IMSMPP07
00  24
29
IMSLATE
IMSMPP07
00  24
Change the parameter or the schedule plan for job APCIJINV accordingly.
Line Commands
To work with the system information entries that are displayed among the list, place the cursor to the left of the entry and enter one of the following line commands:
Line command
Function
I
Inserts a new user defined system entry representing an IMS region measurement
C
Changes the system name of an existing system entry
D
Deletes a system entry
