Previous Topic: Deleting Performance Measurement History - APCDJREONext Topic: Defining Parameters
Maintaining the Database - APCIJRDR
Job APCIJRDR performs the following database maintenance functions:
The job JCL for APCIJRDR is shown following:
//JOBCARD…
//* SAVE WITH REPRO, DELETE/DEFINE CLUSTER, LOAD WITH REPRO          *
//* DEFINE WHICH CLUSTER YOU WANT TO GET MANAGED                     *
//* 0=NO FILE   1=GO GET IT                                          *
// SET GETIMSF=1     IMS DATA CLUSTER           -KSDSIMS-
// SET GETIPPF=1     IMS PROFILE CLUSTER        -RRDSIPP-
// SET GETIMOF=1     IMS CHANGED MODULE CLUSTER -KSDSIMO-
//* FILES :      IMS DATA FILE                                       *
//*              IMS PROFILELIST FILE                                *
//*              IMS CHANGED ONLINE MODULES FILE                     *
//* Copyright (C) 2012 CA. All Rights Reserved.
//* Copyright (C) Trilog AG.
// IF (&GETIMSF EQ 1) THEN
//* DELETE POSSIBLY EXISTING KSDSIMS TEMPFILE
//DELIMST  EXEC PGM=IDCAMS
//SYSPRINT  DD  SYSOUT=T
//SYSOUT    DD  SYSOUT=T
//SYSTSPRT  DD  SYSOUT=T
//SYSIN     DD  *
   DELETE CAMAT.PMA.REPROIMS
   SET MAXCC=0000
//* IMS CLUSTER -KSDSIMS-
//KSDSIMS1 EXEC PGM=IDCAMS
//SYSPRINT DD SYSOUT=*
//INDD     DD DISP=SHR,
//            DSN=KSDSIMS
//OUTDD    DD DISP=(NEW,CATLG,DELETE),
//            SPACE=(CYL,(50,10)),
//            DCB=(LRECL=8189,RECFM=VB,BLKSIZE=8193),
//            UNIT=SYSDA,
//            DSN=CAMAT.PMA.REPROIMS
//SYSIN    DD *
  REPRO INFILE(INDD) OUTFILE(OUTDD)
//KSDSIMS2 EXEC PGM=IDCAMS,COND=(0,NE)
//SYSIN DD DISP=SHR,
//         DSN=CAMAT.PMA.CNTL(DEDEFIMS)
//KSDSIMS3 EXEC PGM=IDCAMS,COND=(0,NE)
//TEMP     DD  DISP=OLD,
//         DSN=CAMAT.PMA.CNTL(REPROIMS)
// ENDIF
//* END OF KSDSIMS PROCESSING
// IF (&GETIPPF EQ 1) THEN
//* DELETE POSSIBLY EXISTING RRDSIPP TEMPFILES
//DELIPPT  EXEC PGM=IDCAMS
//SYSIN     DD  *
   SET MAXCC=0000
//* IMS CLUSTER -RRDSIPP-
//KSDSIPP1 EXEC PGM=IDCAMS
//INDD     DD DISP=SHR,
//            DSN=CAMAT.PMA.RRDSIPP
//            UNIT=SYSDA,
//            DSN=CAMAT.PMA.REPROIPP
//SYSIN    DD *
//KSDSIPP2 EXEC PGM=IDCAMS,COND=(0,NE)
//         DSN=CAMAT.PMA.CNTL(DEDEFIPP)
//KSDSIPP3 EXEC PGM=IDCAMS,COND=(0,NE)
//TEMP     DD  DISP=OLD,
//         DSN=CAMAT.PMA.CNTL(REPROIPP)
// ENDIF
//* END OF KSDSIPP PROCESSING
// IF (&GETIMOF EQ 1) THEN
//* DELETE POSSIBLY EXISTING KSDSIMO TEMPFILES
//SYSIN     DD  *
   DELETE CAMAT.PMA.REPROIMO
//* IMO CLUSTER -KSDSIMO-
//INDD     DD DISP=SHR,
//            DSN=CAMAT.PMA.KSDSIMO
//            UNIT=SYSDA,
//            DSN=CAMAT.PMA.REPROIMO
//SYSIN    DD *
//KSDSIMO2 EXEC PGM=IDCAMS,COND=(0,NE)
//         DSN=CAMAT.PMA.CNTL(DEDEFIMO)
//KSDSIMO3 EXEC PGM=IDCAMS,COND=(0,NE)
//TEMP     DD  DISP=OLD,
//         DSN=CAMAT.PMA.CNTL(REPROIMO)
// ENDIF
//* END OF KSDSIMO PROCESSING
