When your application workload is distributed across multiple online regions, it is helpful to define region summary definitions.
All information about each of the single regions that are assigned to a summary region are put together and stored under the defined summary region name.
For example, if the SMF data contains information about transactions from regions CICSPRD1 and CICSPRD2 and you define a summary definition CICSPROD containing the 2 regions, then all information available for the 2 single regions will be aggregated under CICSPROD.
Select option C5 on the Parameters Menu to access the CICS SMF Aggregation Control panel shown following.
APCCPA00 --- PMA CICS Feature SMF Aggregation Control ------- Row 1 to 6 of 6 COMMAND ===> SCROLL ===> HALF Commands : INS - INSert Line Commands: I -Insert D -Delete C -Change LC PMA Region System Name Name ------------------------------------------------------------------------------- CICSSUM1 CICSAOR1 CICSSUM1 CICSAOR2 CICSSUM1 CICSAOR3 CICSSUM2 CICSAOR4 CICSSUM2 CICSAOR5 CICSSUM2 CICSAOR6 ******************************* Bottom of data ********************************
This panel displays the current defined aggregations.
You can insert (add) new definitions or delete or change existing definitions by using the following line commands:
Line Command |
Function |
I |
Displays an input screen that is prefilled with the information from the line where the command was entered This data can be used as a model for building up a new aggregation definition by changing the System or Region name. |
C |
Displays an input screen that is prefilled with the information from the line where the command was entered |
D |
Deletes the selected definition A confirmation panel is displayed where you are asked to continue with the delete or to cancel the operation. |
You can also use primary command INS (Insert) to enter a new system aggregation definition. This command displays an empty version of the the System Aggregation Definition panel, as shown following.
APCCPA01 --------- System Aggregation Definition ---------- COMMAND ===> PMA System Name: Region Name : CANCEL: CAN OR PF3 SAVE : ENTER
