Previous Topic: Including and Excluding SystemsNext Topic: CICS SMF Summary Definitions
Including and Excluding Transactions
Select option 2 on the CICS SMF Scope Definitions panel to access the Transaction In/Exclusion List panel shown following.
APCDPS20 --- PMA - Transaction In/Exclusion List (CIC ENTRY INSERTED COMMAND ===> SCROLL ===> HALF Commands : I -Insert Line Commands: I -Insert D -Delete C -Change If EXCLUDED the following Transactions are NOT in the CICS SMF scope If INCLUDED ONLY the following Transactions are in the CICS SMF Scope LC Tran IN/EXCLUDED Description ------------------------------------------------------------------------------- TRX1 EXCLUDED EXCLUDE TRANSACTION TRX1 ******************************* Bottom of data ********************************
You can use line commands to work with a specific inclusion/exclusion or to insert a new transaction. To use line commands, place the cursor in the LC column to the left of the transaction and enter one of the following values:
I
Insert a new transaction exclusion or inclusion.
D
Delete an existing transaction exclusion or inclusion.
C
Change the name or description of an included or excluded transaction.
You can also use primary command I (Insert) to enter a new transaction inclusion or exclusion.
If you choose to insert (I) or change (C) a transaction exclusion or inclusion, the panel shown following is displayed.
APCDPS21 --- PMA - Insert Transactions In/Exclusion (CICS SMF Scope) COMMAND ===> Please enter: Transaction : TRX1 def. CICS SMF processing spectrum using a Transaction name In/exclusion : E I = inclusion E = exclusion decide whether all System Definitions are inclusions OR exclusions. Description : EXCLUDE TRANSACTION TRX1 use '_' as the placeholder for one byte use '*' as a generic value at the end for example: System ABC123* A__1_345 C1* CANCEL: CAN OR PF3 SAVE : ENTER
Inclusions are recommended when defining transaction names.
Generic notation of transaction names is allowed using * as a wildcard.
For example: TRAN* INCLUDED
In this example, all transaction names that do not begin with TRAN* are implicitly excluded from the CICS SMF Scope.
All defined transaction names must be either inclusions or exclusions.
You are not allowed to mix these definitions.
