Use the following steps to enable the Server to collect SMF data indirectly by using the spooling interface option:
APCSPMNU ------- PMA --- Server Component Menu ----------------- Release 8.5 OPTION ===> 4 1 Commands - Issue Server Commands 2 Time Events - Set Time Events 3 Time Alerts - List Time Generated Alerts 4 Options - Set Selectable Features 5 Spool - PMA SERVER Spooling Parameters 6 Parameters - General PMA SERVER Parameters T TUTORIAL - Obtain PMA Help X or END - End Server Component Dialog COPYRIGHT (C) 2012 CA. ALL RIGHTS RESERVED. COPYRIGHT TRILOG AG
APCSPP02 ------- PMA SERVER - Option Setting ----------------------------- COMMAND ===> (If D the Default Measurement Duration is used for all Dynamic Alerts) End of Step Alert Generation : Y enter Y or N (If Dynamic Alert set to Yes, only non-alerted steps considered) Time Alert Generation : Y enter Y or N Max no. Alerts to be generated per entry : 3 enter no. from 1 to 10 Max Threshold Alert Generation : Y enter Y, C or N (If C conditional only generate Max Threshold alert if in measurement scope) Min Threshold Alert Generation : Y enter Y, A or N (If A all min values must be exceeded before a job is eligible for runaway) PXI Threshold Alert Generation : Y enter Y or N SMF Recording by Server : S enter Y, S or N (If S recording to the KSDSJOB file is indirect, via a Spooling Interface) Cancel: CAN Save : END OR PF3
When the Server option for SMF recording is set to Spool (as shown previously), it is necessary to start the spool interface started task, APCSASIP, in addition to the Server started task.
More information:
Startup JCL for the spool interface task APCSASIP
Activating the spool interface started task
