To define the Server spooling parameters, select option 5 on the Server Component Menu to display the following panel.
APCSPP03 ------- PMA SERVER - Spool Parameters ------------------------------- COMMAND ===> Data Set Allocation Parameters Non SMS parameters (ignored if files are SMS controlled) VOLSER for use with Spool files : volume name or blank UNIT " : SYSDA unit type or blank SMS parameters (ignored if files are not SMS controlled) MGMTCLAS for use with Spool files : management class or blank STORCLAS " : storage class or blank Spool Control Parameters Spool transfer interval : 10 5-60 minutes Refresh the Top Scope values every: 144 12-999 Spool transfers (interval * frequency = refresh period in minutes) Cancel: CAN Save : END OR PF3
In the Spool Parameters panel, you can define both data set allocation parameters and spool control parameters, as discussed in the following sections.
