Previous Topic: Using Minimum Consumption ThresholdsNext Topic: Server minimum threshold check at the end of job step execution
Server minimum threshold check during job step execution
This threshold check is done only if the feature option is set to Y or A and at least one minimum threshold is set. The values checked during execution are CPU time, I/O count, and elapsed time. Only the non-zero threshold values are used to check if a threshold has been reached.
If the feature option is set to A, all of the non-zero threshold values must be reached for a job to be eligible for measurement. If the feature option is set to Y, reaching any non-zero threshold makes the job eligible for measurement.
