Both primary commands and line commands are allowed on this panel.
If line command I or C, or primary command INS (abbreviation I) is entered, the Define PIX Threshold Values panel is displayed.
APCBPPX1 --- PMA - Define Performance Index Alert Thresholds ------------------ COMMAND ===> Job name : Job name or generic job name (using '*') '_' is a placeholder for one byte '*' is a generic value used at the end Examples: Job name Comment * all jobs (default) PRJ123* all jobs starting with PRJ123 P_J_2345 all jobs with two wild cards SRVU/EL Ratio: 000000000 Performance Index SRVUs/Elapse time( sec ) CPUT/EL Ratio: 000.00 Performance Index CPU time of Elapse time EXCP/EL Ratio: 000000000 Performance Index EXCPs/Elapse time(min) SRVU/IO Ratio: 000000000 Performance Index SRVUs/EXCPs CPUT/IO Ratio: 000000.00 Performance Index CPU time(sec)/EXCPs in thousands ELAP/IO Ratio: 000000.00 Performance Index Elapse time(sec)/EXCPs in thousands CANCEL: CAN OR PF3
Performance index threshold values for a job or a generic job group can be entered.
Enter the job name for which thresholds shall be defined.
Generic notation is allowed.
Note: An asterisk must be used to represent one generic entry on the list.
Enter the threshold for that performance index that is the quotient of service unit consumption divided by used elapsed time.
Enter the threshold for that performance index that is the quotient of CPU time consumption divided by used elapsed time.
