Previous Topic: Performance Index Alert ThresholdsNext Topic: Search Mode
Defining Performance Index (PIX) Alert Thresholds
When you choose option TX on the Parameters Menu, the List Performance Index Alert Thresholds panel is displayed. Use this panel to enter performance index alert threshold values to be examined by PMA.
APCBPPX0 --- PMA - List Performance Index Alert Thresholds -------------------- COMMAND ===> SCROLL ===> HALF Search Mode : F ( F = First B = Best ) Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change ------------------------------------------------------------------------------- LC Jobname SRVU/Elap CPUT/Elap EXCP/Elap SRVU/EXCP CPUT/EXCP Elap/EXCP ------------------------------------------------------------------------------- ******************************* Bottom of data ********************************
You can enter performance index alert threshold values for a job or a generic job group. Each job step with consumption values higher than or equal to the specified thresholds generate a threshold alert. Before entering values into this table, it is highly recommended that you get some experience with the specific behavior of performance indexes in your installation by watching the performance index display functions of the Central Component.
Thresholds for each job or job group are represented by two detail lines on the bottom half of the panel. This area of the panel can be scrolled.
