When you choose option AS on the Parameters Menu, the MODC alert suppression panel is displayed. If there are already defined some entries, they are shown in the list panel. Use this panel to enter module change alert suppression to be examined by Alert Handling of the Central Component.
APCBPP26 --- PMA Central Component - MODC alert suppression ------------------- COMMAND ===> Job names 1 : D1* Job names or generic job names (using '*') Job names 2 : _S_J* '_' is a placeholder for one byte Job names 3 : _A* '*' is a generic value used at the end Examples: Job name Comment PRJ123* all jobs starting with PRJ123 P_J_2345 all jobs with two wild cards _P* all jobs with 'P' as second letter ACTIONS: CAN (to leave panel unchanged) OR PF3 (to store changes)
You can define up to three job names or generic job names. If the Alert Handling of the Central Component would set a pending alert for a specific job because of changed module, the pending alert and the following measurement on the next run of the job is suppressed if the job name does match with one pattern entry of the module change alert suppression list.
