Previous Topic: Panel ElementsNext Topic: Panel Elements
Defining Procedure Libraries
When you choose option X7 on the Parameters Menu, the List Procedure Libraries panel is displayed. Use this panel to enter procedure libraries to be examined by PMA.
APCBPP07 --- PMA Central Component - List Procedure Libraries Row 1 to 2 of 2 COMMAND ===> SCROLL ===> HALF Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change Concatenation Data Set Name of LC Number Procedure Libraries ------------------------------------------------------------------------------- 01 PROD.PROC.LIB1 02 PROD.PROC.LIB2 ******************************* Bottom of data ********************************
You can enter the name of your procedure library or libraries here. During the JCL scan, the libraries are concatenated. As a user, you can determine the concatenation order by entering the concatenation sequence number when inserting the name of a new procedure library.
If no entries have been made, Central Component does not recognize program calls within procedures (except program calls within standard procedures). In this case, the Central Component immediately displays the insert panel when signing on to General Parameters - Procedure Libraries.
