When you choose option X4 on the Parameters Menu, the List Standard Procedures panel is displayed.
APCBPP06 --- PMA Central Component - List Standard Procedures Row 1 to 4 of 4 COMMAND ===> SCROLL ===> HALF Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change LC Procname Procstepname Parm No. DD Name Parm Name(s) ------------------------------------------------------------------------------- DB2IMS IMS PRG DB2ONLY DB2X 05 SYSTSIN N2 XST DD1 PRG UPRG N4 NST P2 P4 ******************************* Bottom of data ********************************
In many cases programs are called through standard procedures (for example, standard DB2® procedures). Often, the name of the module to be executed is passed through a parameter. Through the panel for managing standard procedures you enable Performance Management Assistant to detect and measure calls from standard procedures.
