Previous Topic: Panel ElementsNext Topic: Panel Elements
Defining Standard Programs
When you choose option X3 on the Parameters Menu, the List Standard Programs panel is displayed.
APCBPP04 --- PMA Central Component - List Standard Programs -- Row 1 to 3 of 3 COMMAND ===> SCROLL ===> HALF Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change LC Program Parm No. DD Name Parm Name(s) ------------------------------------------------------------------------------- DFSRRC00 02 DSNMTV01 09 DDITV02 IKJEFT01 SYSTSIN PGM PROGRAM ******************************* Bottom of data ********************************
In certain cases, in-house written programs are called from standard programs as a kind of subprogram. Often, the name of the module to be executed is passed through parameters or through a DD statement. By using the Standard Programs panel, you enable the Central Component to detect user programs that are executed through a standard program. If one of the user programs has changed or was inserted, an alert entry is generated. Without the standard program information, the user program call would not be recognized and no entry would be generated.
