The following panel is displayed when you choose option U1 on the Parameters Menu:
APCXPP01 --- PMA - Global Print JCL ------------------------------------------- COMMAND ===> Enter your user specific JCL statements used in all PMA features for Print: //XXXXXXXX JOB12345,XXX,CLASS=X,MSGCLASS=X //* //PRINT EXEC PGM=IEBGENER //SYSIN DD DUMMY //SYSPRINT DD SYSOUT=* //SYSUT2 DD SYSOUT=* //SYSUT1 DD * Cancel: CAN Save : END OR PF3
Some options within the online dialog of components allow you to print information. Use this Global Print JCL panel to define the job card and JCL statements to be used when routing information to the printer. This print JCL is saved separately for each TSO user.
