After selecting Step 4, the following panel displays.
CUSTPT04 ---- PMA V90 Customization - Verify PMA Target DS Names -------------- COMMAND ===> Please verify the names of the PMA Target Data Set Names: REXX Library (PO) : CAMAT.PMA.CEETEXEC Panel Library (PO) : CAMAT.PMA.CEETPENU Message Library (PO) : CAMAT.PMA.CEETMENU LOAD Library (PO) : CAMAT.PMA.CEETLOAD AUTH Load Library (PO) : CAMAT.PMA.CEETAUTH HELP Library (PO) : CAMAT.PMA.CEETHELP CANCEL: CAN SAVE: ENTER
The panel lists the product libraries that are established through the SMP/E installation process.
If the listed names are incorrect, type the correct names that the product libraries were created with in this panel.
CUSTPT00 ------------------- PMA V90 Customization Dialog --------------- COMMAND ===> 5 Step Status =============================================================== 4 Verify PMA Target Data Set Names COMPLETED
