After selecting Step 3, the following panel is displayed.
CUSTPT03 ------- PMA V90 Customization - Specify operational defaults -------- COMMAND ===> Data set attributes- PS: UNIT: SYSDA VOLUME: SUFFIX: - PO: UNIT: SYSDA VOLUME: SUFFIX: - VSAM: UNIT: SYSDA VOLUME: SUFFIX: - TEMP: UNIT: SYSDA VOLUME: Blocksize at LRECL=80 : 6160 - 32400, blank if system managed SMF Spool GDG Limit No.: 3 03 - 99 CANCEL: CAN SAVE: ENTER
Enter the UNIT, VOLUME and SUFFIX specifications used to create the PS (physical sequential) product data sets.
Enter the UNIT, VOLUME and SUFFIX specifications used to create the PO (partition organized) product data sets.
Enter the UNIT, VOLUME and SUFFIX specifications used to create the VSAM KSDS and RRDS product data sets.
Enter the UNIT and VOLUME information to be used for intermediate files.
If you are not using a storage management system, you can enter any blocksize between 6160 and 32400, provided it is a multiple of 80.
Enter the number of generations to keep for the SMF spool file. A minimum of 3 is required; 99 is the maximum value. The default is 3.
Step 3 is marked as COMPLETED, as shown following, and you can continue with Step 4.
CUSTPT00 ------------------- PMA V90 Customization Dialog --------------- COMMAND ===> 4 Step Status =============================================================== 3 Specify operational defaults COMPLETED
The status of Step 3 stays NOT COMPLETED.
