Previous Topic: Using the Online Customization DialogNext Topic: Viewing the Customization Job Log
Verifying Execution of Customization Jobs
The Customization Main Menu lists each of the customization steps and indicates whether the step has been completed. The step completion includes customization jobs that have to be submitted and observed in your spooling facility.
If, for some reason, the last job has not been completed normally, you are prompted with the Customization Inquiry panel.
CUSTPINQ ------------- PMA V90 Customization - Inquiry ------------------------ COMMAND ===>        A normal termination has not been confirmed for customization job CUSTJxxx       One of the following conditions/actions is applicable:        1. You did not submit the last job that was reviewed in edit mode.                 Enter command CAN and repeat the customization step.        2. You submitted the job, but the job has not finished yet.                        Observe the job in your spooling system. If the job terminates normally,       press ENTER to continue with the next customization step.        3. The job has terminated abnormally.                                              Enter CAN to repeat the customization step and resolve the JCL problem.        4. The last job submitted has terminated abnormally however you accept this.       Be aware that the success of the customization might be adversely affected.     Enter command ACCEPT to continue with the next customization step.              Your acceptation will be logged in the customization Log.
