After calling the Online Customization Dialog the Customization Control entry panel displays to define the name and storage attributes for the Customization Control Library, required to receive and provide customization definitions and to track the customization progress, to enable a user to leave and reenter the customization process.
CUSTPTSU --------------- PMA V90 Customization Control ----------------------- COMMAND ===> To start the customization process for the CA Mainframe Application Tuner Performance Management Assistant please enter the name of the control library to be used for customization definitions and progress tracking. If the library does not exist it will be created dynamically. Customization Control Library: Name: YOUR-HLQ.CUST If the Customization Control Library does not exist, create it on: Volume: * Enter Volume ID or * if SMS managed Press ENTER to continue or press F3/END to leave the customization. ************************************ * CA Mainframe Application Tuner * * Performance Management Assistant * * Version 09.0.00 * ************************************ COPYRIGHT (C) 2012 CA. ALL RIGHTS RESERVED. COPYRIGHT TRILOG AG
After the customization control file was created, the Customization Main Menu displays.
CUSTPT00 ------------ PMA for CA MAT Customization Dialog --------------------- COMMAND ===> 1 Step Status 1 Specify HLQ and Job Card for Customization Jobs NOT COMPLETE 2 Create PMA Parameter Data Set NOT COMPLETE 3 Specify operational defaults NOT COMPLETE 4 Verify PMA Target Data Set Names NOT COMPLETE 5 Verify PMA User Data Set Names NOT COMPLETE 6 Verify PMA Data Cluster Names NOT COMPLETE 7 Create PMA User Data Sets NOT COMPLETE 8 Create PMA Data Cluster NOT COMPLETE 9 Create PMA Start Exec NOT COMPLETE 10 Create PMA JCL Member and JCL Procs NOT COMPLETE 11 Customize Measurement Product Interface NOT COMPLETE 12 Upgrade NOT COMPLETE L Show Customization Log X END ************************************ * CA Mainframe Application Tuner * * Performance Management Assistant * * Version 09.0.00 * ************************************ COPYRIGHT (C) 2012 CA. ALL RIGHTS RESERVED. COPYRIGHT TRILOG AG
On the Customization Main Menu, all customization steps are presented in sequence.
Before continuing with the next step, the status of the previous step must have a status of COMPLETED.
See Customizing Steps for a complete description of each of the steps on the Customization Main Menu.
