CAPOLY$TRAP is equivalent to CATRAP on other CA NSM platforms. To use CAPOLY$TRAP, the following steps are required:
catrap :== $capoly$bin:capoly$trap
Value |
Usage |
Description |
destination-node |
destination-node |
Target system for the message |
enterprise |
enterprise |
OID for your enterprise |
agent-addr |
agent-addr |
Address of the agent |
generic-trap |
generic-trap |
Trap type |
specific-trap |
specific-trap |
Specific trap type |
time-stamp |
time-stamp |
Time of message |
-d |
[-d] |
Hex dump of packet |
-v |
[-v] |
Verbose output |
-t |
[-t timeout] |
Overrides default timeout, where timeout identifies the new timeout |
-r |
[-r retries] |
Overrides default number of tries, where retries identifies the new number of retries |
-p |
[-p port] |
Identifies the port to use instead of 162, where port identifies the new port |
-c |
[-c community] |
Overrides default community string, where community identifies the new community string |
Note: You can make enterprise, agent-addr, and time stamp default by using a null (“”) string.
For example:
catrap hosta 1.3.6.1.4.1.791.2.8.2.2.2 "" 6 2 "" 1.3.6.1.4.1.791.2.8.2.2.2.1 octetstring “My string A” 1.3.6.1.4.1.791.2.8.2.2.2.1 octetstring “My String B”
Notes:
The Registry value MsgTimeout is the lifetime (timeout) in seconds for outgoing CAM messages. It allows you to control message timeout according to your network capabilities. The default value is 10 seconds. The parent Registry key is:
HKEY_LOCAL_MACHINE\SOFTWARE\ComputerAssociates\UNIVMS
The logical name UNIVMS_MSG_TIMEOUT is the lifetime (timeout) in seconds for outgoing CAM messages. It allows you to control message timeout according to your network capabilities. The default value is 10 seconds. To change the value, edit SYS$STARTUP:CAPOLY$STARTUP.COM. Remove the comment from the line that defines the logical name. Change the value as desired and save the changes.
