Previous Topic: Using CAPOLY$TRAP
Next Topic: PROCESS Data Items
Using Performance Cubes
The Performance Agent component of CA Performance Management for OpenVMS can create a performance data file, called a cube, which is readable by CA NSM Performance Manager on the CA NSM Management station. When you install the Performance Agent on OpenVMS, you are asked questions related to the creation of this cube, including if you want to activate the Performance Cube functionality.
Note: You do not have to activate this functionality for CA Performance Agent for OpenVMS to function properly on an OpenVMS system.
When activated, Performance Agent creates a cube file and periodically transfers that cube file to the CA NSM Management station. When you install CA Performance Agent on an OpenVMS system, the following text file is created:
CAPOLY$DATA:CAPOLY$CUBE_OPTIONS.DAT
This file is created whether or not a CA NSM Management Station exists and whether or not you activate the functionality. Creating this file ensures that you do not have to completely reinstall CA NSM Performance Agent for OpenVMS to activate the functionality. This file contains the following information:
The following lists include the default data items and their default setting (Y or N) in the cube options supplied during the installation. Data items are organized into groups of related items.
For a brief description and interpretation of these data items, see chapter 5 of the CA Performance Management for OpenVMS Performance Agent Administrator guide.
This section contains the following topics:
PROCESS Data Items
DISK Data Items
MAGTAPE Data Items
COMM Data Items
CPU Data Items
HOTFILE Data Items
CONFIG Data Items
SYSTEM Data Items
