Previous Topic: Defining a Foreign Symbol
Next Topic: Using CAPOLY$TRAP
Using CAPOLY$CASEND
CASEND is a simplified version of CAPOLY$TRAP that sends an informational message using SNMP traps to one or more CA NSM Managers. To use CASEND, the following steps are required:
  1. Define a foreign symbol:
  2. casend :== $capoly$bin:capoly$casend.exe
  3. Arguments for CAPOLY$CASEND:
Value
Usage
Description
message
message
The message you want to send, as a quoted string
destination-nodes
destination-node
Target systems for the message
By default, CASEND will send the message to nodes defined by the logical CAPOLY$TRAP_DST. If a comma-separated list of nodes is provided as the second argument, then the trap will be sent to these nodes and not the nodes defined by the logical.
For example:
casend “This is a test message”
or
casend “This is a host message” hosta,hostb,hostc
