Previous Topic: Editing the System Startup Command File
Next Topic: Re-installing CA Job Management
Editing the System Shutdown Command File
You can edit your system shutdown file so that the agent shuts down properly when your system performs an orderly shutdown. To do this, add the following command line to the system shutdown file, SYS$MANAGER:SYSHUTDWN.COM:
$ @SYS$STARTUP:UNIJM$AGENT$SHUTDOWN.COM
If you activated CA Common Services for OpenVMS, you can add the following command:
$ @SYS$STARTUP:CAPOLY$SHUTDOWN.
