This chapter considers reinstallation requirements and processes.
The JM Manager must be reinstalled after OpenVMS upgrade. For example, if you installed JM Manager on OpenVMS 8.2 and then upgraded to OpenVMS 8.3, you must reinstall JM Manager. The JM Manager installation links executables with current system libraries, and those executables might not work properly after OpenVMS upgrade.
When reinstalling in a cluster, you may perform just one installation for all the nodes with the same architecture and OpenVMS version. Those nodes must share node-specific directory NSCHED$EXE, so the reinstalled executables will be effective on all nodes. Select any node among those nodes to run the installation on. Be sure to specify the same node-specific directory as the existing one. If however you decide to specify another node-specific directory, you must edit SYS$STARTUP: UJM$MANAGER$STARTUP.COM on ALL nodes that share this directory and alter the definition of the NSCHED$EXE logical name.
