Previous Topic: Shutting Down CA Job Management Agent
Next Topic: Editing the System Shutdown Command File
Editing the System Startup Command File
You can edit your system startup command file so that the agent is automatically started when your system is rebooted. To do this, add the following command line to the system startup file, SYS$MANAGER:SYSTARTUP_VMS.COM:
$ @SYS$STARTUP:UNIJM$AGENT$STARTUP.COM
Place this new command line after the line that invokes the network startup command procedure. For example:
$ @SYS$MANAGER:STARTNET.COM
In addition, place the CA Job Management Agent startup command after the line that invokes the TCP/IP services startup command procedure. For example:
$ @SYS$STARTUP:UCX$STARTUP.COM
If you activated CA Common Services for OpenVMS, you do not need to run the commands above. Instead, just run @SYS$STARTUP:CAPOLY$STARTUP.
