The installation procedure allows you to choose the temporary directory used for the savesets and installation files. Choose a device and directory with at least 170,000 free blocks. The following example shows how to select a device and directory:
* Enter the device and directory to unzip the save-sets, 170000 blocks of temp space needed [sys$common:[CA$SETUP]]:
Note: 21, 000 free blocks are the minimum for Alpha; the minimum free blocks for Integrity are 25,000.
