The installation consists of a number of steps designed to check your system, install Job Manager, and then initialize Job Manager. You must complete the following tasks in the following order:
For a sample installation, see Examples of New Installations.
Note: Default answers to the installation questions below are provided in brackets. For example, "[YES]" indicates the default answer is YES. You can accept the default by pressing Enter. For answers other than the default, type your answer and press Enter.
