Previous Topic: Step 16. Choose Products for Automatic Startup after Installation
Next Topic: Step 18. Specify the UIC of the CAUNIVMS account
Step 17. Specify the CA NSM Manager System
The installation prompts you to specify the node name, which is usually the same as the node name you already specified, or IP address of the system where CA NSM Manager is running, as shown in the following message.
To complete integration with a CA NSM Management Station,
its IP address or node name is required.
The CA NSM Manager has been identified as:
"vmstest0"
* Node Name or IP Address [vmstest0]?
If, at a later time, you want to change the system name, you can do so by using the following command procedure:
@sys$manager:CAPOLY$SET_STARTUP_PARAMS.COM
