Previous Topic: Step 15. Activate the CA NSM Integration Components (optional)
Next Topic: Step 17. Specify the CA NSM Manager System
Step 16. Choose Products for Automatic Startup after Installation
If you choose to activate UCS Integration, the installation displays the Product Startup Selection menu (shown below) listing all the products that you can choose to start automatically after installation and asks if you are satisfied with the displayed choices.
	    CA NSM/CCS for OpenVMS - product startup selection
	1   CA Job Management.................................   YES
	2   CA Job Management Agent...........................   NO
	3   CA Universal Job Management Agent.................   NO
	4   CA NSM Jobflow Support ......................,,,,,,  YES
	5   CA Job Management NSM/CCS Integration.............   YES
	6   CA Console Management.............................   NO
	7   CA System Watchdog................................   NO
	8   CA System Watchdog NSM/CCS Integration............   NO
	9   CA Performance Management Agent...................   NO
	10  CA NSM Performance Trend Cube .....................   NO
	11  CA Common Services OpenVMS Gateway ................   YES
	* Are you satisfied with the product selection Y/[N] ? y
The installation automatically sets the value for the product that you are installing to YES. If you responded YES to the question about activating CA NSM/CCS integration components, then the value for item 11 (CA Common Services OpenVMS Gateway) is also set to YES.
In a clustered environment, you may not have licenses for all components on all nodes. This menu enables you to select components separately for each node. You can also customize the startup list by using the following command procedure while logged onto each node:
@sys$manager:CAPOLY$SET_STARTUP_PARAMS.COM
