You should always back up your system disk before installing any new software. If you need to restore your former system settings, you want the most current information saved. To ensure you have a good backup, the installation asks if you are satisfied with your backup. Select one of the following responses:
If you are satisfied with the backup of your system disk, press Return to accept the default YES.
Type NO and press Return to stop the installation. Back up your system disk, and then restart the installation.
