Previous Topic: Step 2. Run the Installation Procedure
Next Topic: Step 4. Check Your System Backup
Step 3. Specify a Temporary Directory to Unzip the Savesets
The installation procedure allows you to choose the temporary directory used for the savesets and installation files. Choose a device and directory with at least 70,000 free blocks. The following example shows how to select a device and directory:
* Enter the device and directory to unzip the save-sets, 70000 blocks of temp space needed [sys$common:[CA$SETUP]]:
Note: 70,000 free blocks are the minimum for Alpha; the minimum free blocks for Integrity are 95,000.
