Previous Topic: Loading Jobs to Display
Next Topic: Adding to the Currently Displayed Job
Clearing and Changing the Currently Displayed Jobs
If you want to clear the displayed jobs and display new jobs, you must first clear the Display windows and then select new jobs to display, as follows:
  1. Click on the Clear button in the Graphical Display window or Linear Display window.
    Note: If you do not click on the Clear button, any new jobs that you select are added to the jobs currently displayed.
    All jobs are removed from both Display windows.
  2. Click on the Load Jobs... button in either window.
    The Load Jobs dialog box is displayed.
  3. Click on one or more fields in the dialog box and edit information for new jobs. You can move the text cursor and insert characters, use the delete key, or you can highlight characters and use pending delete. You can clear all fields in the dialog box by clicking on Reset.
    The characters appear in the fields as you type.
  4. Click on OK.
    The new jobs that match the criteria you specified are displayed in both Display windows.
