Previous Topic: Clearing and Changing the Currently Displayed Jobs
Next Topic: Locating Jobs by Scrolling
Adding to the Currently Displayed Job
To add more jobs to those currently displayed, follow these steps:
  1. Click on the Load Jobs... button in either Jobs Display window.
    The Load Jobs dialog box is displayed.
  2. Click on one or more fields in the dialog box and edit information for new jobs. You can move the text cursor and insert characters, use the delete key, or you can highlight characters and use pending delete. You can clear all fields in the dialog box by clicking on Reset. See the table in Loading Jobs to Display for a description of the fields.
    The characters appear in the fields as you type.
  3. Click on OK.
    The new jobs that match the criteria you specified are added to both Display windows; you may need to use scroll bars to locate the new jobs.
