Previous Topic: The Load Jobs Dialog Box
Next Topic: Job Management Manager Linear Display Window
Job Management Manager Graphical Display Window
The Graphical Display window provides a graphical display of jobs in the Job Management Manager database. Each box shown in this window represents a job. Each job is labeled with its job number preceding and followed by its job name. Refer to Interpreting Your Job Display for more information about interpreting your job display.
The Graphical Display window also lets you display a Navigation window that allows you to select and display portions of the window that are not visible, and to change the size of boxes displayed (see Using Navigation Windows).
The menu bar on this window provides the following five pull-down menus:
Pressing and holding MB3 on a job in the Graphical Display window displays a pop-up menu with the same options on the Jobs pull-down menu. Moving the pointer over Control and dragging the mouse to the symbol
[-> displays a submenu with the same choices found on the Control pull-down menu. To select one of these submenu items, move the pointer over the menu item you want and release MB3.
