The following table shows Compile and Catalog DIAL command codes (set by SET COM @I$DIAMASK session command).
Code |
Module |
Description |
Dial‑A |
CMAEXP CMPDEO CMCDEI CMFATL |
Compiler arithmetic expression parser Prt data‑entry object: debugging Compile data‑entity initializer Compiler fatal error processor |
Dial‑B |
CMCEXP CMBCBS CMBCTR CMNORM |
Condition analyzer main mod Build CBS work area COND ANAL TO BUILD COND TREE NORMALIZE A CONDITION TREE |
Dial‑C |
CMCTRL CMFINL |
Compiler control module Compiler release resources mod |
Dial‑E |
CMERR |
Compiler error msg processor |
Dial‑F |
CMCDET CMCDEP CMCDEC CMODEO CMASST CMAS CMASMR CMASMX ADDCMP |
Compile data‑entity terminate Compile data‑entity process Compile data‑entity create Obtain data‑entity object Compiler attribute services ‑ stow Attribute Services Compiler attribute services: merge Comp attribute services: Auxiliary merge Catalog dataview processor |
Dial‑I |
CMINIT |
Compiler initialization pgm |
Dial‑J |
ADSQLE ADDBQI |
BATCH DBSQLE DB Q‑COMMAND INTERFACE PGM |
Dial‑L |
CMLX CMLXSX CMLXSL |
Compiler lexical analyzer Lexical select error message processor Compiler lexical select |
Dial‑P |
CMLOOP CMLIST CMMAPP CMGENP CMGENX CMAUXP CMADSB CMCALP CMDVWS CMFORE CMFORN CMFORW CMPRDC CMSELX |
Compiler loop stmt parser List statement parser Compiler panel stmt parser Compiler parser control module Compiler‑generate final blocks ASS/RES/SET‑ID STMT PARSER Compiler add/sub stmt parser CALL Statement Parser Delete, checkpoint, backout statement For each p‑code generator For next p‑code generator P‑code generator of “for new” Compiler “produce” statement module Compiler select parser |
Dial‑Q |
CMTGEN CMPREP CMSCOP CM2GEN CMDBQP CMGENQ CM2PAR |
Compiler t‑code generator Compiler SQL prepass pgm Compiler scope analysis SQL string generator DB SQL Parser SQL PASS DRIVER DB2 SQL Parser |
Dial‑R |
RWAEXP RWANAL RWCF RWCOL RWDET RWPH RWTGEN RWUTIL CMRWDR CMRWER |
RW: Arithmetic expression analyzer RW: analyze detail RW: control footing RW: column analysis RW: detail RW: page heading RW: t‑code generator top level RW: compiler utility RW: Compiler driver COMPILER: RW ERROR HANDLER |
Dial‑S |
CMTPAD CMTRAN CMSEXP CMSSTR CMGPMV CMNFNC CMGSTR CMINDX CMEDIT CM$$DT CM$GSF CM$STR |
Compile Trim‑Pad function $translate function parser Compiler string expression parser $substract function parser COMPILE GROUP MOVE Compile numeric function Compile group string $index function parser $edit function parser $date, $time parser Compile General string function Compiler $string function parser |
Dial‑T |
CMTGEN |
Compiler t‑code generator |
Dial‑U |
ADDB2R |
DB2 catalog traverse |
Dial‑Z |
CMPRTP CMPREF |
Compiler print processor Print cross reference list program |
